Fibaro rgb module with homeseer?
Posted: Sun Jul 28, 2013 7:52 pm
by bartbakels
Dear all,
Anyone tried the new fibaro rgb module especially in combination with homeseer? Or any other comments on this unit. It looks very promising to me. But i doubt if it works in homeseer 2.
Regards
Bart
Re: Fibaro rgb module with homeseer?
Posted: Wed Jul 31, 2013 4:56 pm
by airox
I don't use Homeseer. Am also eagerly expecting this module. Judging by the manual it is capable of mimicking itself as a dimmer with multiple channels. This would make it simple to integrate with current Z-wave libraries I guess. Unfortunately in the "normal" way it is using a color control set Z-wave command class. I haven't seen this on any other z-wave device so far. So I *guess* Homeseer would need an update for this. And also I would need to get information from somewhere how to implement this in my own z-wave library...
Still... the hardware itself is pretty impressive. All crammed in a small module! Fibaro home center suddenly became a lot more interesting!
Posted: Tue Aug 20, 2013 11:51 pm
by bartbakels
Dear all,
The module (fibaro rgbw) works great with homeseer. It created for dimmer devices to control the colour channels a main controller and 3 powermeter devices. Great News..
I just bought one for testing amd this is the conclusion
Posted: Sun Aug 25, 2013 6:12 pm
by airox
Can you also go to a certain color without adjusting each of the channels?
Posted: Sun Aug 25, 2013 6:27 pm
by bartbakels
No, not with homeseer. I think you need scripting. In addition there are builtin modes such aa colorfade however this is a parameter and not accessible by scripts. Maybe someone else have an solution.
Regards bart
Posted: Wed Oct 09, 2013 11:24 pm
by airox
Bart,
Is there some option to show some z-wave "on-the-wire" logging? I am curious how Homeseer is sending a specific channel change (R or G or B) to this device. Got one also and it only seems to respond to SWITCH_MULTILEVEL_CHANGE and BASIC_SET but only for all the channels (so I can only dim white light on an RGB strip). If you have some raw debug logging this would be fine. I can integrate this in my driver / maybe open-zwave driver.
Especially interested if it's using the COLOR_CONTROL_SET ...
Posted: Thu Oct 10, 2013 8:44 am
by bartbakels
Airox,
This kind of logging can be enabled in the homeseer ini. Dont know the exact entry but if u google it you will find it. I can remeber I used this before.
regards
Bart Bakels
Posted: Thu Oct 10, 2013 7:48 pm
by airox
Bart,
The problem is... I don't have Homeseer
I'm just interested in a piece of logging to see which bytes get send when you turn on a channel (for example red). I can reverse engineer this to get a hang of how the module works and implement this on the open-zwave driver.
Greetings,
Gijs
Posted: Mon Sep 21, 2015 3:16 pm
by raymonvdm
Did anyone ever managed to use the "fireplace, storm, rainbow, police lights" ?
http://forum.micasaverde.com/index.php? ... #msg125234
Posted: Tue Sep 22, 2015 9:19 am
by bartbakels
Yes i managed to implement this in HS3, by a script, and since the newest zwave plugin via events (set configuration parameter).
parameter 72 to value X (programma)
I use this for alarm tripping (police program)
Bart
Posted: Tue Sep 22, 2015 9:21 am
by raymonvdm
bartbakels wrote:Hi,
Bart
Would you mind sharing the script ? so i can see what values is can use and to set the values
Posted: Tue Sep 22, 2015 9:56 am
by bartbakels
You dont need the script , its a zwave action in the events now.
Bart
Posted: Tue Sep 22, 2015 9:58 am
by raymonvdm
bartbakels wrote:You dont need the script , its a zwave action in the events now.
Bart
Aha, but where can i find the values i did not find them in the manual of the RGBW module
Posted: Wed Sep 23, 2015 10:09 pm
by Chiel
Values 1-10.
6= fire-like light
7= kind of lightning, random white flashes and then slowly dimming blue light
8= rainbow with bright colors
9= rainbow with softer colors
10= rapid flashing red/blue/white
I only have an rgb strip attached to it, play with the values.
