Which Motion Detector (end of life: Xanura BSX1)
Posted: Tue Mar 11, 2008 9:02 pm
by acfnews
Hi All,
Are there any tips for a (good) motion detector to be used for staircase lightning via X10/A10 ?
I believe the Xanura BSX1 is a good option, but it seems end of sale...
My requirement is a 220volt device, with X10/A10 embedded.
Thanks for any help,
Ron
Posted: Tue Mar 11, 2008 9:47 pm
The MS13 motion sensor is een exact copy of the Xanura BSX1 and still widely used. With this kind of setup there is always a time delay before the lights are switched on.
http://www.elekhomica.nl/product_info.p ... ucts_id=57
BTW: Are you sure it's not delivered anymore? knowing Xanura there should be a new model then?
Posted: Tue Mar 11, 2008 10:23 pm
by TANE
You can build your own.
Motion sensor from jung
http://www.hateha.nl/jung/techniek/Auto ... elaars.htm
[img]uploaded/chak/200831121232_aut.sc23.jpg[/img]
Connect the sensor to SAIX12/AIX12
This way is more comfortable with any delay.
Posted: Tue Mar 11, 2008 11:39 pm
by Henk
In case 230V is closely available any 230V motion detector may be used ... the new XanuraHome modules can handle 230V input and has a second input ... in case using the other Xanura modules do some internal modifcation by cutting the 230V lead to the switching relay inside the motion detector.
Henk
Posted: Tue Mar 11, 2008 11:43 pm
by Snelvuur
@chak, i was thinking about that jung + sensor, but the total package does come out a whole lot more $$$. A ms13 is cheap easy, and with a rfxcom pretty darn fast in responding.
Posted: Tue Mar 11, 2008 11:53 pm
by TANE
Hornbach have one for about 20 euro (sensor)
Posted: Wed Mar 12, 2008 12:33 am
The Xanura SAIX12 can handle the 230V motion detectors. I believe the Jung motion detector has a actor within, so no status update and automatic switching or is there a combination with the SAIX possible?
Posted: Mon Mar 17, 2008 9:49 pm
by acfnews
Hi All,
Thanks for the feedback.
Most sensors run on batteries, i really like to stick to 220v.
Looks like i need to go with a seperate interface.
Also i could use a 'potentiaal vrij' one as i use the Xanura HCB. It does have some inputs for this use.
Does anyone have experience with Klemko's devices : http://www.klemko.nl/user_files/Aanwezi ... %2032m.pdf
They appear not that expensive, but still adjustable for hight/depth and light/dark...
Grtz,
ron
Xanura HCB, and some interfaces
