I managed to add the everspring sp814 to my homeseer system, and made an association within group 1 with homeseer. However when i want to change the parameters in order to adjust sensitivity level, lux level setting etc the configuration value is set at ERROR and cannot be saved when changed.
Anyone experience with this?
Everspring SP814 motion sensor
Re: Everspring SP814 motion sensor
You have to wake up battery devices, and send the changes just after.
Regards
Morten
Regards
Morten
It would be helpful to have a step-by-step description here how to configure this e.g. in Homeseer II.
Gert
Gert
Thank you Morten, I will give that a try.mhn wrote:You have to wake up battery devices, and send the changes just after.
Regards
Morten
I also have an SP814 but after 2 days it goes blind. (until battery re-seat) What settings are you trying maybe i can check ?
Mine is not going blind and I still use the factory settings, I can provide you with the factory settings if you want but maybe a total reset is easierraymonvdm wrote:I also have an SP814 but after 2 days it goes blind. (until battery re-seat) What settings are you trying maybe i can check ?
Its working, thank you for your advicemhn wrote:You have to wake up battery devices, and send the changes just after.
Regards
Morten
You happen to know how to use the lux settings/readings in a device/ event?
My guess is you can use Device Value Change.
Regards
Morten
Regards
Morten
- Starting Member
Previously I do have that SP814 and believe me it was like really horrible since after every 3rd or 4th day it goes blind and it just like a very irritating thing for me so I decided to change it by foscam and it works great no problem at all.basklj wrote:I managed to add the everspring sp814 to my homeseer system, and made an association within group 1 with homeseer. However when i want to change the parameters in order to adjust sensitivity level, lux level setting etc the configuration value is set at ERROR and cannot be saved when changed.
Foscam ?
