Pir which is very good for outside.
Posted: Tue Nov 19, 2013 1:05 am
by Dylantje
Pir which is good.
I am looking for a pir outside, and preferably without antenna.
He must be supported by the RFXcom.
He may not send a bomsignaal as the KaKu.
I see:
MS 13
MS 18
MS 90
Not really one for outside, someone who knows? [ watherproof is what i need ]
Which work well and are recommended by you?
There are more types of brands that are good, i connot find them?
I love to hear from you
Re: Pir which is very good for outside.
Posted: Tue Nov 19, 2013 1:15 am
by Akatar
some kind of rfxcom has room for a slave reciever, visonic
http://rfxcom.com/store/Receivers/40079
then you can use a outside pir
http://www.waakzaamwonen.com/tower-20am ... p-281.html
Posted: Tue Nov 19, 2013 1:30 am
by Dylantje
Akatar wrote:some kind of rfxcom has room for a slave reciever, visonic
I have the USB transceiver..?
Is this working on the usb?
I like the 868 to...
Posted: Tue Nov 19, 2013 9:15 am
by Phaeton
no. Then you'll have to buy a lan version.
Posted: Tue Nov 19, 2013 8:46 pm
by mbliek
The MS13 has a small antenna and works good outside.
Posted: Tue Nov 19, 2013 11:44 pm
by Dylantje
But not waterproof... :roll: :roll:
Posted: Wed Nov 20, 2013 7:31 am
by mbliek
it is. See this description from Marmitek:
Switches lights and appliances on while present and switches them off later. Switches outdoor and indoor lights on when you come home in the evening. Saves energy by automatically switching lights and appliances off in empty rooms. Protects your home by early detection of unexpected visitors. Automatically route lights to the bathroom, for instance. Completely wireless. Splash waterproof for inside and outside use.
Posted: Wed Nov 20, 2013 7:19 pm
by Dylantje
Thanks..
Only Splash waterproof is not waterproof.
And i can not make a "roof" on the pir...
That is the reason that is search for waterproof.
Posted: Wed Nov 20, 2013 8:30 pm
by Akatar
Posted: Wed Nov 20, 2013 8:46 pm
by Dylantje
Thanks
It is a option.
Only Wired?
And is this working in Domticz?
edit : p
Posted: Wed Nov 20, 2013 8:51 pm
by Akatar
Dylantje wrote:Thanks
It is a otion.
Only Wired?
no it's not a lotion
Posted: Wed Nov 20, 2013 9:01 pm
by mbliek
It is a otion.
Only Wired?
If you connect the wired pir to the marmitek DS90 it is working with domoticz. Then you can also use the DS90 for your door or window ;)
Posted: Wed Nov 20, 2013 9:37 pm
by Dylantje
Thank you.
That's a nice option, that might work for me.
Only I can not find again or the DS90 waterproof is?
And give the wired pirsensoren like standing in the example, no bomsignaal.
Otherwise I have the same problem with this, like the KaKu pirsensor.
Posted: Wed Nov 20, 2013 10:41 pm
by mbliek
No. You should hang the DS90 inside and bring a wire too the outside.
The DS90 in part of the marmitek security and sends no bomsignal.
