Two days ago i installed a Vera Lite with a AN157-2 (on-off switch) and a AD142 (dimmer).
Including the two modules was quite easy.
I tested the system in many ways and in that proces a invalid plugin was created.
I gave the Vera Lite an factory reset and now my list of devices became empty.
I tried to include the AN157 and AD142 again.
That did not work. The modules wil not go into include mode anymore.
Is there any way that I can reset the modules?
Thanks in advance.
Guus.
Reset AN157-2 and AD142
Re: Reset AN157-2 and AD142
Did you try to exclude the modules first?
Normally you can include them again after exclusion.
Leo
Leo
I tried to exclude, but appearently it did not work.
Is there another solution?
Guus.
Guus.
Sorry I don't have a AN157 to try only AN158-2.
For An158-2 exclusion works when you set the controller in exclusion mode and press the button on the module 3 times within 1.5 sec.
Leo
Leo
The devices (modules) are not in de controler (Vera Lite) anymore.
They disappeared after a the factory reset of the Vera Lite.
So there is no way (as far as I know) that I can exclude the modules with the Vera controler.
Guus.
Guus.
you have to exclude the units it doesn't matter if they are not included on the vera.
just exclude them and then you can include them again
Problem solved.
Was a lack of knowlegde.
I used the exclude option with the ad Advanced Z-Wave devices under Ad Devices.
Thanks Akatar. Your answer made me look into de vera software again.
Guus.
Guus.
