Allows you to quickly read SATA hard drives without installing them
Hot swap USB docking bay for all SATA hard drives
Supports both 2.5 inch and 3.5 inch drives
Far easier to use than a USB enclosure
Quick release eject button
USB 2.0 transfer rate upto 480Mbps
Funny device from http://www.maplin.co.uk/Module.aspx?ModuleNo=222999
SATA Hard Drive USB Docking Station
Moderator: TANE
I've seen them some time ago when I was over in the US.
Really nice, but they are really heavy!
They've put something heavy in it to keep it from not moving around when spinning up.
Never start anything you can't fi
If you have more PC's and want to exchange data fast, this is also a nice solution: http://www.raidsonic.de/de/pages/produc ... ectID=4291. I use one of these in my PC. It is cheaper to buy an extra 500GB harddisk than to burn stuff on DVD.
Hotswap of harddisks is supported (If your motherboard supports AHCI).
Als het niet kapot is, niet repareren!
