I just received one of these :
Bluetooth Watch MBW-150 Executive Edition
http://www.sonyericsson.com/cws/product ... iveedition
I got mine here :
http://www.coolsound.nl/product/9216/so ... _executive
You can use them with a windows mobile phone :
http://forum.xda-developers.com/showthr ... ?p=1960856
http://forum.xda-developers.com/showthread.php?t=362218
but I'm working on some code, to use the watch with with a PC, for home automation purposes (XP SP2 bluetooth stack)
I've already got some rudimentary test code working :
To receive 5 different button presses from the watch:
(volume up/down, stop, play, next)
To send graphic images (96x16) to the watch.
If you use a small font, you can squeeze 2 or 3 lines of text in a graphic.
Note, that if an image is displayed, the above keys are blocked until you press the 'hang up' button, to hide the picture again (because the image is meant for caller id purposes)
you can make the watch vibrate
You can make the watch scroll a 192x16 image a few times (meant for currently playing music track, so music icon is always displayed and above keys still work during display)...
You can alternate two texts on the screen, using a font built into the watch (meant for caller name+phone number,so caller id icon is also displayed)
A volume control 'bar' is built-into the watch and volume up/down commands, can be received in the pc (not without also displaying the 'volume bar').
note : that this watch needs regular recharging (every couple of days to 2 weeks, depending on bluetooth use)
note : that this thing is very heavy (stainless steel).
Music: 85 g; Classic: 77 g; Exec: 182 g ...
In hindsight, I should have probably ordered either the 'classic' or 'music' version, which are lighter (and a little cheaper) :
http://www.coolsound.nl/product/9221/so ... _150_music
http://www.coolsound.nl/product/9218/so ... 50_classic
Marcel
Sony-Ericsson MBW-150 bluetooth watch
Moderator: TANE
Now that looks like fun.
Do you know what the battery life is when using the bluetooth?
Never start anything you can't fi
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by wifi</i>
<br />Do you know what the battery life is when using the bluetooth?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">not yet, I've only just got it and it probably depends on how often something is displayed on the OLED screen..
I don't expect more than a couple of days, if connected 24hrs a day...
Marcel
Marcel
I've made some progress, writing a girder plugin :
here's an example of 2 line text, using the 04b03 8pt font
http://www.getfreefonts.info/free_font.04b03.html
in girder, you would do this :
here's an arbitrary test graphic
in girder, you can use the gd graphics library :
also, currently, for front door access, I do a bluetooth discovery to detect my (not-paired) phone, which is quite slow (takes maybe 5 seconds)
If the (paired) watch comes into bluetooth range (i.e. I stand outside the front door) then I just need to press a button on the watch and in < 1 second, it is connected.
girder then receives a 'connected' message, which includes the unique MAC address of the watch and then I could open the door automatically...
Marcel
MBW150.ImageText("04b03",8,"This is Line 1\nand this is Line 2")
local im = gd.createTrueColor(96, 16)
local black = im:colorAllocate(0, 0,0)
im:filledRectangle(0, 0, 95,15, black)
local white = im:colorAllocate(255,255,255)
im:line(0,0, 95, 15, white);
im:line(0,15, 95, 0, white);
im:rectangle(0, 0,95, 15, white);
MBW150.Image(im:gdStr());
Marcel
- Snelvuur
MAC address can be spoofed though, so make sure you have a second authentication in place. But the first sniffing mac address spoofing burglar are yet to be found..
I'm sure it is theoretically possible...
I never heard of a bluetooth mac spoofing device ?
(people are mainly concentrating on WIFI)
It is a very unlikely scenario, that people would sit outside my door (in a flat on the second floor) with a laptop and some special hardware/software...
anyway, I think that I would accept 'security through obscurity' [8D]
and not add an additional retina/fingerprint/hand shape sensor...
Marcel
Marcel
girder plugin is published here :
http://www.promixis.com/forums/showthread.php?t=18244
it includes source code...
Marcel
Marcel
see pictures of the first examples how the watch could be used :
basically, the 'stop' (middle left) button is always used to change mode.
if you press this button within 5 seconds, it activates the next mode.
Otherwise, it displays the current mode for about 2 seconds
modes :
*heating
-shows current room temperature and temperature setpoint.
-volume up/down changes the setpoint
*lighting
-shows current dim level setpoint
*zone
-shows current active zone for music (living room/office/bedroom)
-volume up/down changes the zone
*music
-only affects the active zone
-each time a new track starts playing, then the artist+title is shown for 2 seconds.
-the 'play' button pauses/plays the song
-the 'next' button selects the next song in the playlist
-volume up/down changes the volume of the music
(email/voicemail/caller id notification pops up a message and also causes the watch to vibrate)
volume
zone
music
lights
heating
Marcel
modes :
*heating
*lighting
*zone
*music
volume
zone
music
lights
heating
Marcel
Looks great Girder man
