AeON usb on a RPI
Posted: Wed Dec 18, 2013 12:25 am
by Dylantje
Can someone explain to me how to get the AEON USB stick working on a RPI?
Re: AON usb on a RPI
Posted: Wed Dec 18, 2013 12:51 pm
by strongetje
with SER2NET.
apt-get install ser2net
put your aon stick in the Rsapberry.
run the command
and look to the line :
[200695.461117] usb 1-1.3.1.1: cp210x converter now attached to ttyUSB0
then put this in the ser2net.conf (you find here /etc/ser2net.conf)
#BANNER:banner:\r\nser2net port \p device \d [\s] (Debian GNU/Linux)\r\n\r\n
3001:raw:0:/dev/ttyUSB0:115200 NONE 1STOPBIT LOCAL
ttyUSB0 you change in wat you found with dmesg.
put this line in your /etc/rc.local
/usr/local/sbin/ser2net -c /etc/ser2net.conf
yust before the exit o line.
then ser2net service starts when the RPi boots
then in Homeseer add zwave , ethernet device.
IP from your Raspberry and port 3001.
hope you understand, my english not so good.
greats,
Mark
Re: AeON usb on a RPI
Posted: Wed Dec 18, 2013 1:01 pm
by Dylantje
Thanks.....
Is this the same for domoticz?
My englies is batter....
Posted: Wed Dec 18, 2013 2:27 pm
by strongetje
hello Dylantje,
thanks to Raymon, he sent me the info.
i'm think it's the same for domoticz.
greetz,
Mark
Posted: Wed Dec 18, 2013 7:36 pm
by raymonvdm
If you are using domoticz on the same pi as where the Z-Wave stick is connected you can use dmesg to find out which port it gets when pluggin the stick in
It wil indeed tell you something like this
After that you can tell domoticz you`re zwave stick is located at /dev/ttyUSB0
If you are using a remote pi you can follow my
instructions as explained by Strongetje
p.s. Is Domoticz supporting USB Z-Wave yet ? In the manual i only see reference to RaZberry
