Domotiga Thermostaat action
Posted: Fri Jan 24, 2014 4:55 pm
In DomotiGa i have made a scipt to use a opentherm thermostat (simple version) on a thermostat in domotiga (timer function)
this reads the current requested temperature
Thermostat.GetRequestedTempForHeating(1, 1)
when i make this action
Devices.ValueUpdate(36, 1,Thermostat.GetRequestedTempForHeating(1, 1) )
he should update value 1 of Device 36 (the opentherm thermostat) width the requested temp of the domotiga thermostat.
This is working when i view the device values in the devices tab in domotiga. but the opentherm thermostat is not reacting,
When i make an action "Set device, opentherm thermostat ... Value 1 to 19.0" this is working fine :S
is there a difference bitween the 2 actions ?
The only difference i can see is the domotiga thermostat creates a value 19 and the action creates 19.0 is this the major problem ?
I made a trigger every minute and a Condition where the trigger checks if the requested value had been changed. if changed then do Devices.ValueUpdate(36, 1,Thermostat.GetRequestedTempForHeating(1, 1) ).
I dont know where to look at it ...
Thanks Ronald
Thanks Ronald
