Delete all alternative Data-ID's
andre_OT
Post by andre_OT »
I know that I can delete alternative Data-ID's, using the DA command.
Than I have to know which ID's I have used in the past.
But when I forgot some of the alternative data-id's that I have used in the past, how will I know that they are there?
Is there a command to clear / delete all these alternative data-id's at once?
Re: Delete all alternative Data-ID's
No.
gizmocuz
Post by gizmocuz »
that would interest me too, also listing them...
You can quite easily find the alternative data ID's the gateway uses by taking a recent otmonitor log and then looking for messages preceded by an R, e.g.:
grep -o R[08]0..0000 otlog-20140307.txt | sort -u
Translate the second byte of each line to decimal and issue a DA command with that number to delete it.
