OTMonitor - does it need OTGW?
Posted: Sat Aug 09, 2014 5:09 pm
I hope that this very basic question will be forgiven.
The opening sentence on the OT Monitor at http://otgw.tclcode.com/otmonitor.html says
"The Opentherm Monitor is a small utility that is intended to help you configure and monitor your opentherm gateway."
Does this mean that the OTGW is essential for the OTM to operate?
I have put the OTM onto Ubuntu and it opens up nicely but obviously doesn't monitor anything yet.
If I were to buy the necessary TTL to USB cable and add the rJ 9 connector can I simply plug it into my Remeha Avanta and monitor the data exchanges between it and my thermostat?
Note that, at present, I do not want to send any data to the boiler. I just need to see and record the data flow.
Many thanks
Many thanks
