Page 1 of 2
How to detect power outage ?
Posted: Fri Aug 29, 2014 8:33 pm
by soitjes
Last week when we came back from holiday we were surprised by a warm fridge because we have had a power outage during our absence. I have a relatively old house and the electrical installation is somewhat sensitive (although recently renewed).
So this gave me the idea that I should be able to detect a power outage, so that I can call the neighbour who can reset the fuse. My home server and router are on a UPS, but that only holds for 20 minutes or so.
Any suggestions on how to detect a power outage ?
Thanks,
Soitjes.
Re: How to detect power outage ?
Posted: Fri Aug 29, 2014 9:09 pm
by raymonvdm
Send an sms from your homeserver as soon as the ups detects a power outage ?
I think you need the following components for this
- UPS (check)
- Server (check)
- Nokia 6230
- Nokia DKU2 usb cable
- Gnokii
http://www.gnokii.org/
- Prepay Simcard
http://www.q8i.org/sms-power-failure-notification/
Posted: Fri Aug 29, 2014 9:33 pm
by Akatar
or..
if you use zwave
220 volt relais
universal binaire sensor
powerout -> relais off -> uni bin sensor report
Posted: Sat Aug 30, 2014 7:01 pm
by AshaiRey
Or turn on the outside lamp near the from door so your neighbour can see if there is an outage or not.
Posted: Sat Aug 30, 2014 11:11 pm
by raymonvdm
Although you might actually want to fix the real issue
Some fridges can be hooked up to your alarm system and the alarm company will check whats wrong
Posted: Sun Aug 31, 2014 12:24 am
But will this result in bills on false positives when someone just forgot to close the door of the fridge?
Posted: Thu Sep 04, 2014 12:40 am
by soitjes
Thanks for the suggestions.
My current idea is to use a Raspberry which I ping continuously. The Raspberry is not on the UPS so the ping will fail when the power goes out. And then I can send a message to myself.
Soitjes.
Posted: Thu Sep 04, 2014 1:13 am
you have an UPS, the software can detect the power outage and send you a mail.....
i have the same construction, my UPS runs on Nodejs
Posted: Thu Sep 04, 2014 12:38 pm
by soitjes
I don't know if my UPS can do that. I bought it second hand and it did not came with software. I'll google it to see if I can find something.
Soitjes.
Posted: Sun Sep 07, 2014 10:02 pm
by dad
I live in a rural area so have a sometimes flakey power supply. I keep track of power failures by using an MQTT topic of the uptime from my RPi.
HTh
Dad
Posted: Fri Dec 12, 2014 5:08 pm
by jeroen_
I got a APC SMT1000I with "Smart" Management Card 2" and these can send email from there.
Of course, that does require the rest of the network to be up and running... kind of funny when the network towards the UPS is over PowerLine and thus the powerline fails because that part does not have connectivity... but at least you get a mail when the power is back
Posted: Thu Dec 18, 2014 7:15 pm
by dad
Just to add that I had an outage last night and by comparing the logged uptime values I was able to tell when the outage occurred and that it lasted 3 minutes 20 seconds.
HTH
Dad
Posted: Fri Jan 23, 2015 1:56 am
by jonbanjo
As others have commented, your UPS probably provides a solution.
We have a couple of APC units at home. They are monitored on Linux systems (one is actaully connected to a Raspberry PI) running apcupsd. With that particular setup, as far as I can remember, the default is to send an email to root when the status changes.
In the /etc/apcupsd folder, there are a number of scripts that are called when an evets occurs, eg. onBattery is triggered when power is lost. One could edit these scripts so that they would execute any command you want, so if you needed, the whole setup is quite "customisable" (if there is such a word...).
Posted: Sat Jan 24, 2015 12:27 pm
by Jeroen Bartels
Don't ask me how but if you agree with a fellow domotician to ping each others system. No ping for x time should trigger an sms from fellow domoticians system to your phone. And you can return the favour of course.
Posted: Sun Jan 25, 2015 12:00 pm
by AshaiRey
While your idea is very nice it isn't testing power outage but it's testing connectivity
