TP-Link wifi module
blueone
TP-Link wifi module
Post by blueone »
Today I also received the opentherm module with wifi module. I am trying to get this to work but is doesn't. I set the tp-link and it is connected proparly. But when I try to open de opentherm monitor I get the following error when I try connect: "Connection failed: Cannot find channel name sock708". I tried to connect the gateway with and without the usb hub between the tp-link and gateway.
raymonvdm
Re: TP-Link wifi module
Post by raymonvdm »
It look like you are searching for channel sock708 but i would expect an IP adres instead of a name.
Maybe if you provided some more details on what you did, it would be easier for people to help you. How did you configure the TP-link? How did you configure otmonitor? Did you check that there is no firewall blocking your access?
