It looks the same as the meters provided for example by Eltako. Including shipping it cost me 40 euro's. This included 2 seal-caps (to isolate the 220V lines from the rest of the fusebox)
And although it is not premier quality (the locking mechanism is made of plastic) it does its work very well. Counts 1000 imp/KWh (S0), has a bright led that flashes every time you consumed 0,001 KWh. I fitted it right after the fuse protecting the airconditioning. It displays two decimals, so 0,01KWh is the minimum it can display.
As soon as the extra 1-wire counter arrives I will hook it up to my 1-wire setup.
You can find the unit at this URL: http://www.eprotech.nl/shop/kWh-meters-p-1-c-16.html
They also sell a analog version that is even 3 euro's cheaper.
Als het niet gerepareerd kan worden dan is het niet kapot!
