Toon app: OV Informatie
Xavier
Re: Toon app: OV Informatie
Post by Xavier »
Thanks, Works as described!
Issue fixed.
hi all,
version 1.1.2 is available in the ToonStore.
Changelog : firmware 5.9.6 compatibility
Xavier
Post by Xavier »
Issue fixed.
Xavier
Post by Xavier »
Since a week or 2 the OV app doesn't refresh the OV information anymore.
Departure of train for example is in the evening still the same time as in the morning. Example: at 07.00 hours it tells me the train wil depart at 7.23. In the evening when coming back from work at 18.00 it is still telling me the train wil depart at 7.23.
Anybody any idea or same issue?
can you check if the problem persists after a gui restart?
EDIT: I see the same here, will have a look
EDIT2: restart of the GUI did resolve it, probably a memory leak of some sort. Will see if I can make some improvements there (at some point in time)
Xavier
Post by Xavier »
Indeed after restart solved.
Thanks!!
Xavier
Post by Xavier »
Any progress on this issue?
Xavier wrote:Any progress on this issue?
It isn't on top of my priority list.
I have only seen one occurrence so far myself, as it was both you and me at the same time it could also have been an issue with the data feed.
I will first release a new version of Toon Store with some gui bug fixes and then move on to do some maintenance on the waste collection app.
kind regardz,
Hi all
A new version 1.1.3 is available in the ToonStore.
Changelog:
- text edit fields (search fields) didn't work on the latest firmware, is now made firmware independent
- user settings moved to /mnt/data/tsc/ov.userSettings.json
- this release is for firmware 5 only, compatibility with older firmwares has been dropped.
- the refresh timer was not started in certain conditions causing the screen not be to refreshed every 2 mins
Amnon
Post by Amnon »
Big fan of this app, but since updating from 1.1.3 to 1.1.4, the information is often not actual/refreshed. It then shows information of hours ago or maybe even the evening before and does never get actualized anymore unless you restart Toon
I am running on FW 5.13.12
Is it possible to go one version back :-) ?
RgR
Post by RgR »
Same problem here! I really love the app, but recently it often shows 'old' information. I hope there is some way to fix it!
atlantica
Post by atlantica »
I think 9292 took their API down. The URL gives an 404 :(
http://api.9292.nl/0.1/locations?lang=nl-NL&q=
I hope there is an alternative :roll:
Seems like everyone needs to request for access to their API:
https://9292.nl/zakelijk/9292-reisadvies-api
Maybe OvAPI is an alternative: https://github.com/skywave/KV78Turbo-OVAPI/wiki
Or NDOV https://ndovloket.nl/
Regards
David
I don't like to ovapi one as it is not covering all bus stops, just the ones listed as 'stop area'
De reisadvies-api is focussed on journey planning, not so much on actual timetables for a specific stop/station.
Will look into other options if I have time.....
