Plugwise and Linux
Plugwise and Linux
Thanks for your offer, I will do when required (are your latest sources available?)
Plugwise and Linux
The latest work is done in my home automation software, not in the pol binary. If you want those sources let me know..
Maarten Damen
www.maartendamen.com
Maarten Damen
Plugwise and Linux
Hi, I just registered today because I actually did not know of this forum. Let me first thank Maarten for his work on pol 0.2. I've just switched my first Circle on and off again using his pol.py. If you have any newer code I'm going to be greedy and ask for it
I had some trouble getting the script to work because I had no clue what the mac addresses should be. I tried the code on the devices themselves at first. That did not produce any error and the prompt did not return. Digging through this forum I found out I had to open an .mdb file to get the full addresses. Opening such files is not straightforward without a copy of Microsoft Office (OpenOffice.org fan here). But I managed to open the thing somewhere and it appears that the mac addresses are in the following format for Circles :
000D6F00003 + 5position unique code. That would produce the following commandline to turn a Circle on :
# ./pol.py -p /dev/ttyUSB0 -o 000D6F000038C08A
(just posting this for future Linux users without access to MS Access )
This is a sig
This is a sig
Plugwise and Linux
There is one problem with pol.py that I've run into. When trying to get the watt figure using the -w, the python script barfs. Has anybody seen this behaviour before?
Platform : Ubuntu 8.10 x86_64
This is a sig
root@freedom:/root/plugwise# ./pol.py -p /dev/ttyUSB0 -w 000D6F000038C08A
File "./pol.py", line 151, in <module>
main()
File "./pol.py", line 135, in main
print plugwise.GetPowerInfo()
File "./pol.py", line 50, in GetPowerInfo
self.GetCalibrationInfo()
File "./pol.py", line 31, in GetCalibrationInfo
self.gain_a = self.hexToFloat(result[0:8])
File "./pol.py", line 70, in hexToFloat
return struct.unpack('f', bits)[0]
File "/usr/lib/python2.5/struct.py", line 87, in unpack
return o.unpack(s)
struct.error: unpack requires a string argument of length 4
This is a sig
- RDNZL
Plugwise and Linux
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by eelco</i>
<br />Hi, I just registered today because I actually did not know of this forum. Let me first thank Maarten for his work on pol 0.2. I've just switched my first Circle on and off again using his pol.py. If you have any newer code I'm going to be greedy and ask for it
I have 000D6F00002 and 000D6F00001 here, sorry! [:o)]
Plugwise and Linux
Hmm error handling isn't very good in pol.py it was merely a proof of concept code. Can you switch this module on and off, and is it currently using watts?
<br />There is one problem with pol.py that I've run into. When trying to get the watt figure using the -w, the python script barfs. Has anybody seen this behaviour before?
This is a sig
Maarten Damen
main()
return o.unpack(s)
This is a sig
Maarten Damen
Plugwise and Linux
Yes I was suspecting a division by zero error, so I switched to Cirle off and on and made sure there was some current running through. Maybe I should try a 32 bit machine?
And I'm not complaining about code quality, I am thankful there is linux code to work with in the first place
This is a sig
This is a sig
Plugwise and Linux
Ah, you are on x64 didn't notice directly.
Phew.. I'd have to test that. I suspect something goes wrong with my hextofloat function...
Maarten Damen
Maarten Damen
Plugwise and Linux
Ah, it is a 64/32 bit problem.
Just tested your script in a virtual machine with Ubuntu 8.04 32 bit and that works without any problems. There is no need to fix it for me, because I will move the USB plug to my "homeserver" which is a 32 bit CPU laptop
I read that you were not working on this code anymore but on some other solution. Care to tell me about your setup / plans? With the basic stuff covered I might want to expand the number of Circles and the Linux tools to manage them.
Thanks for your quick response anyhow.
This is a sig
This is a sig
Plugwise and Linux
Wonderful work!
But I find it hard to get my Mac addresses to my modules. How do I solve this the easiest way, without mixing with Windows?
Am I required to install the source on an XP computer?
Thanks for the answer!
Plugwise and Linux
@plutonium: you need to install and setup the plugs/circles once on Windows XP or similar. After it has been setup you don't need Windows any longer. You can determine the mac addresses of the plugs using the plugwise access database which is by default located under:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">%UserProfile%\application data\plugwise\source\DB<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Maarten Damen
Maarten Damen
Plugwise and Linux
@Maarten: THis is new information to me. Why do you need to initialize the zigbee network from within the Source software?
Plugwise and Linux
Rene, you need to pair your devices with the plug at least when you use a secured plugwise network.
Maarten Damen
Maarten Damen
Plugwise and Linux
Maarten, My compliments for your hard work. I don't have the time right now to implement it on Linux, although i prefer Linux as the basis of my home automation system. I'm planning to write a php or RoR based solution. As these are within my comfort zone. But I will after we moved to our new house in april. For now I was just experimenting with the Source. The only drawback I experienced is the limited distance between the circles.
Do you know if routing and signal strength information is available?
Have a nice day
Have a nice day
Plugwise and Linux
No I don't think that's the problem. I think the problem can be found in the reliability of the wireless ZigBee system. When doing something wrong, it could stop working. With the software of Plugwise this could not happen.
