Temperatuur buienradar blijft vast staan
Boulevard
Post by Boulevard »
Goedemorgen, sinds gisteren verandert de buitentemperatuur van buienradar niet meer...sinds gisteren blijft hij op 4 graden staan.
De buienradar heeft wel contact met internet, want ik zie de radarbeelden wel bewegen.
Is er misschien een storing.?
Ik heb de app al verwijdert en weer opnieuw geïnstalleerd en dat hielp ook niet.
Re: Temperatuur buienradar blijft vast staan
The xml.buienradar.nl file is not updated since 15/4 by buienradar.nl. That is our data source for the app.
They have these service interruptions now and then, just wait for them to fix it. No need to uninstall the app, that doesn't help
EDIT: they now have a JSON data feed which is much more convenient to use (https://data.buienradar.nl/2.0/feed/json)
I have asked them about the XML data feed, it could be that that is not supported anymore.
Unfortunately I have to rewrite the app to use the JSON datasource.... can do over the weekend probably
Boulevard
Post by Boulevard »
Toonz wrote:The xml.buienradar.nl file is not updated since 15/4 by buienradar.nl. That is our data source for the app.
Dank je wel. :)
see above, probably need to rewrite the app to use the new JSON data feed
just received feedback from Buienradar: they will look into the issue with the XML file
mAiden
Post by mAiden »
It looks like this issue is solved. :)
