I am using a RFXCOM receiver/transmitter, and I have some problems with the reception of the Visonic signals. I tried to adjust the antenna's but I am unsure which antenna is responsible for which signal.
Here is a picture. It is a "LAN 2 COM 433.92MHz transmitter + X10/Oregon receiver set (87005)" with a "868.95MHz Visonic slave receiever (40079)".
Can someone identify the three different modules/antenna's? And can the Visonic antenna be extended (assuming it is one of the wire antenna's with a longer piece of wire?)
