How do i.....
How do i.....
If you use the hs rfxcom plugin, then you actived the x10 relay. Either choose status only or full control.
How do i.....
Can you not set the trigger command on "any X10"?
Then it doesn't matter if the signal is On or Off it alwyas fire the event when you push the switch.
- Antoon
- Antoon
How do i.....
You can also add an extra line to your event to set the status of the switch accordenly
Have a look here
http://www.homeseer.com/support/homesee ... meseer.htm
and search for SetDeviceString
Have a look here
