My first contact with Z-wave
I intend to start replacing my existing x10 sensors for z-wave sensors (finally!). So I buy a usb z-wave stick and a multi-z-wave sensor for testing so that i become familiar with z-wave . installing the usb driver went smoothly. Adding the z-wave sensor went differently than I used to, but finally it worked out well. Now I only have the problem that the sensor is not responding after a while. Only at the reset (button on the side) z-wave sensor wake up again. While I've put in the configuration that the sensor must send notifications every 30 minutes to HomeSeer... maybe i have this problem because i have only one node working right now?... (i have only one z-wave sensor yet)
Re: My first contact with Z-wave
Check the config of the sensor
You have to wake up the battery powered sensors beore you can change the configuration.
