Hi, I want to test the RFXCOM sensor SMS script using VoipBuster, without manually removing any sensor.
How to do this (change the value/message of the RFXCOM sensor display panel for a moment) ?
Regards, Fischi
How to test Sensor SMS script using VoipBuster
- b_weijenberg
Re: How to test Sensor SMS script using VoipBuster
enter a value in the alarm level of a sensor.
Thanks,
the email works correct,
but the sms doesn't run :
16.10.2012 18:11:53 - RFXCOM - Sensor SMS failed, result:<?xml version="1.0" encoding="utf-8"?> <SmsResponse> <version>1</version> <result>0</result> <resultstring>failure</resultstring> <description>Invalid number</description> <partcount></partcount> <endcause>19</endcause></SmsResponse>
Where is the issue ?
Reg. Fischi
Reg. Fischi
- b_weijenberg
Invalid number ??
I had some transposed digits.
Now it runs perfect. I hope, VoipBuster is staying alive for many years.
Are there other providers running with RFXCOM ?
Reg. Fischi
Reg. Fischi
