I have a DomotiGa server/client setup using Raspberry PI.
Is RFXCom commander on the client side known to be disabled? All controls on screen are grayed out.
Btw: I can control 3 KuKu devices using device control in the client, so RFXCom is working/transmitting.
DomotiGaServer: RFXCom commander disabled in Client?
Moderator: RDNZL
Domotiga
Cubietruck, Ubuntu server 1.0.2
RFXcom LAN, home brew ground plane antenna
KaKu
KaKu
Re: DomotiGaServer: RFXCom commander disabled in Client?
It depends a little bit on how the commands are send to RFXCom ...
If you run in client mode, some commands are send via xml to the server, but not all (only will work directly on the server). Yes, this is somewhat confusion and hopefully we can get this "resolved" when the WebGUI is finalized, then we should have xml command for each option.
OK, thanks for explaining uAlex73.
I don't have to investigate further then.
OWK
OWK
Domotiga
KaKu
KaKu
