Ok so I have homeseer and the acrf2 plugin working..
the scale works too... a guy generously gave his .vb for homeseer to do the weight for 4 people....
so I have
4 virtual people
1 scale
and it all works...
I just downloaded the rfxcom charts and dont know how to set it up..
I dont see a section for the scale in the .ini
also no sample chart to go by.. my rfx.mdb is empty....
yes the event runs but I think because I dont have the .ini configured nothing is getting into the .mdb...
anywho...
also I noticed a rfxcom plugin for homeseer.. is this opposed to the acrf2 plugin?
so theoretically if you have the rfxcom plugin you do not need the acrf2 plugin? or can you run both?
Thanks
Jeff
RFXCom Charts and oregon scale
- Starting Member
- b_weijenberg
Jeff,
The RFXWeight chart is only available for use with the RFXCOM plug-in.
For European users the RFXCOM plug-in is a must if they like to control the KlikOn-KlikOff, DomiaLite, NEXA, ELRO AB600 RF modules and Harrison electrical curtains.
And the latest version of the RFXCOM transmitter can also control the HomeEasy products. Those devices have a DIM level possibility which is also implemented in the RFXCOM plug-in.
Bert
Bert
- Starting Member
Thanks for summing it up...
but I have the w800 antennea.. and need it... sooooo I would have to buy an rfx one and the plugin to get this to work.. or just upgrade my acrf to acrf2...
decisions.. decisions....
I am going to be hopefully buying the power monitoring kit later this year.....
