Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Probably something wrong at Meerlanden.nl or the waste2api platform.
I can't get your calender either, the provided links via the website are not working
- Starting Member
Hi Toonz,
Thank you for the update. Been offline for a while for some personal reasons. Will also check or poke them to fix it. Thanks!
Hi, is it possible to add RWM to the app?
RWM.nl is using mijnafvalwijzer.nl.
Select provider 1 in the settings screen and fill in your postcode/housenr
Thanks, it works!
I changed the WastecollectionTile.qml and get the icon at the top right of the screen in a Toon 1.Toonz wrote: ↑Sun Jan 02, 2022 5:46 pm you can make the following change for now in the file /qmf/qml/apps/wastecollection/WastecollectionTile.qml :
replace the 7 lines :withCode: Select all
visible: dimState ? (!app.wasteIconShow && !app.wasteIcon2Show) : true // only show in non-dim if no icons are shown
to go back to the original behaviourCode: Select all
visible: !dimState
Is it possible to have the icon at the old position, which was at the center of the screen below the time?
you can uninstall the app via the ToonStore en reinstall again to get the original file back. Your settings will be preserved....
I added borssele.nl.
Go to the settings screen of the app and select provider 49.
Enter your zipcode/housenr and press 'Opslaan'.
Toon will download the new plugin and restart once to activate it.
- Advanced Member
Great, thank you!
Hi!
Is it possible to also add gemeente Goes as well?
https://afvalkalender.goes.nl/
Example ICal download url:
https://afvalkalender.goes.nl/2022/4461VM-85.ics
Thanks in advance!
Best regards,
Tmmm
Thanks in advance!
Best regards,
Tmmm
Sure, you can now select provider 50 : goes.nl.
Enter zipcode/housenr in the settings screen and press opslaan (Toon will restart once after getting the new plugin for Goes)
Wow that was fast! Thanks!
Hi, it seems that castricum moved to another site: mijnafvalzaken.nl which is not (yet) in the list. Until a few weeks ago it was mijnafvalwijzer.nl.
Could mijnafvalzaken.nl be added?
I want to change some icons on my rooted toon2
Is there any restriction on the used icons ?
Colour depth / transparency ?
I edited an existing icon in Adobe Photoshop and saved it as png but it was not visible
