Moode Audio controller
Joskep
Post by Joskep »
Hello, an question:
Is it possible that one of the technical guys :D makes an app to control the 'Moode Audio' ?
Thats an alternative to the 'Volumio', in my opinion a more stable program for the Raspberry Pi.
See:
https://moodeaudio.org/
And:
https://github.com/moode-player/moode/b ... /setup.txt
I volunteer as an tester :wink:
oepi-loepi
Re: Moode Audio controller
Post by oepi-loepi »
Maybe ik you can post a full list of the rest api urls of moode like :
http:// moode/command/?cmd=play
http:// moode/command/?cmd=pause
http:// moode/command/?cmd=next
http:// moode/command/?cmd=previous
Please find the urls needed in the volumio app:
https://raw.githubusercontent.com/ToonS ... erTile.qml
And
The url to get all info from the mood (in volumio it is api/v1/getState)
Joskep
Post by Joskep »
Thanks.
Do you mean that i have to give you the output of this commands?
On this website (i think) most of the commands are mentioned: https://github.com/moode-player/moode/b ... /setup.txt
AND
https://github.com/moode-player/docs/bl ... 20guide.md
But i want to test everyting, so if i can do anyting let me know (also via PM)
oepi-loepi
no, i have send two links of the volumio controller app. In that app there are urls's to controla and read the volumia controlller. I need to receive the urls's to control the Moode controller. So please try to find them and post them here. It is undoable to read all information on Moode.
Joskep
Post by Joskep »
Okay, i will send an PM thats easier i think.
Joskep
Post by Joskep »
I see you can use moode.local (in stead of local ip).
This commands:
http://moode.local/command/playback.php ... mpd_status
Gives this output:
{"volume":"54","repeat":"0","random":"0","single":"0","consume":"0","partition":"default","playlist":"340","playlistlength":"84","mixrampdb":"0","state":"play","song":"2","songid":"3","time":"0","elapsed":"5903","bitrate":"128 kbps","audio":"44100:24:2","nextsong":"3","nextsongid":"4","song_percent":"0","audio_sample_rate":"44.1","audio_sample_depth":"24","audio_channels":"Stereo"}
Thats a start :- )
Joskep
Post by Joskep »
Is there somebody who can help with this app? I have a few working commands so i think its possible :-)
Joskep
Post by Joskep »
Nobody? :wink:
For all Volumio users....Moode Audio is much more stable :-)
