Toon app: PostNL
glsf91
Re: Toon app: PostNL
Post by glsf91 »
version 1.1.18 is available in the ToonStore with updated login process.
Edgar
Post by Edgar »
Thanks for the update. As it's the first version I use and don't expect any packages yet, so can't see if it really works :mrgreen: To make it clear it's for packages only?
glsf91
Post by glsf91 »
Edgar wrote:Thanks for the update. As it's the first version I use and don't expect any packages yet, so can't see if it really works :mrgreen: To make it clear it's for packages only?
Yes, only packages.
and it will also show your packages of the last x (configurable) months
bafplus
Post by bafplus »
I just installed it on my Toon2 even tho i expect no packages i should see my history for say a month right?
It stays empty at the moment...
bafplus wrote:I just installed it on my Toon2 even tho i expect no packages i should see my history for say a month right?
Can you check the folder /var/tmp/postnl ?
It contains some postnl-resp?.tmp files where you can see potential error messages
sambir
Post by sambir »
I have the latest postnl app and i can see in the tmp log that botdetect=true. what can i do? because it doesnt seem to pick up any info?
ah, same here. Stopped working 5 days ago..... needs some redesign again (sigh....)
EchoNL
Post by EchoNL »
App is not working on my Toon 2, keeps loading. Entered the right password and username. Already a tweak / solution found to solve the problem?
Postnl tightened the security again, at the moment login is only accidentally successful. Probably best to wait for a next release (if we can fix it that is)
Snowhite0901
Post by Snowhite0901 »
Since no new posts here also no success?
no, the app is discontinued unfortunately
