activehome
Ren
activehome
Post by Ren »
Anywhone experiences with these products?
http://www.x10.com/activehomepro/active ... iwcam.html
It looks very attractive and ease to use and installate. Prices are ok.
I wonder if it works proparly also.
drmacchi
activehome
Post by drmacchi »
You mean software ActiveHomePro , or the ninja cams with pan tilt base. If so Yes, i use the base. see here http://www.domoticaforum.eu/topic.asp?TOPIC_ID=1545
About tha cam: i don't thinks it's really a good one, i mean generally they 're used for videosecurity and this brings to have IR led for night, waterproof, working in summer and winter too. That's because i used only the base mounting one porfessional security cams. Hope it helps. Cheers
Ren
activehome
Post by Ren »
I noticed you use homeseer also. Is the original software of activehome not sufficient? What are the main differances?
drmacchi
activehome
Post by drmacchi »
Completely another world! I've been using Activehome (not pro), because it's free when you buy cm11 interface, but change is unbeliveble, you can do everything with Homeseer and its plugins. Just an example : secuirty is all over The net , i can control everything everywhere i am, temperatures, moisture, lights, everything is in your hands! If you have to buy something, buy Homeseer!
