HSTouch
HSTouch
<br />PDA scherm met camera
Opmaak is nog niet optimaal maar het werkt wel.
Beeld komt redelijk soepel binnen +/- 4 p/s
scherm is 480x640
[img]uploaded/Chak/200811116553_pdahs.gif[/img]
scherm is 480x640
HSTouch
Video kan worden toegevoegd via image
volgende settings heb je nodig,
[img]uploaded/Chak/20081212104311_HSTVideo.gif[/img]
voor de Axis 241Q video stream kan je de volgende url gebruiken
http://user:password@<ip>/axis-cgi/jpg/image.cgi?resolution=4CIF&camera=1&compression=10
HSTouch
Zo had ik het aan het werk, maar dan is het enkel een plaatje.
Kan je niet echt 'streamen' naar de HSTouch client?
HSTouch
Mooi is dat.
Komt 100% zeker door de HSTouch plugin.
12-12-2008 12:23:37
Exception of type 'System.OutOfMemoryException' was thrown.
HomeSeer version: 2.3.0.9
Source: System
Target: MemoryChunk AllocateMemoryChunk(Int32)
Stack trace:
at System.Net.ScatterGatherBuffers.AllocateMemoryChunk(Int32 newSize)
at System.Net.ScatterGatherBuffers.Write(Byte[] buffer, Int32 offset, Int32 count)
at System.Net.WebClient.DownloadBitsState.RetrieveBytes(Int32& bytesRetrieved)
at System.Net.WebClient.DownloadBitsReadCallbackState(DownloadBitsState state, IAsyncResult result)
at System.Net.WebClient.DownloadBitsReadCallback(IAsyncResult result)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.ContextAwareResult.CompleteCallback(Object state)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Net.ContextAwareResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Sockets.BaseOverlappedAsyncResult.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Please specify what you were doing at the time of this error: I have no clue.
HSTouch
Als je de instellingen zo hebt zoals in platjes krijg je gewoon streaming op je HST client.
HSTouch
Klopt.. Maar een die steeds update (wat ook niet echt een probleem is)
Ik had gehoopt dat het een echte stream was.
HSTouch
het is een echte stream...andere stream technieken werken ook op een vergelijkbare manier.
voordeel hiervan is je bent niet afhankelijk van een andere video client.
HSTouch
Tja. Voor mij is een echte stream +/-29 frames per seconde, en niet iets van 1 per seconde.
Maar goed. Het werkt zo ook goed zoals het nu is.
Ik ga even verder stoeien met Photoshop en HSTouch.
HSTouch
hstouch zit op +/- 15 frames
HSTouch
Hmm Ik haal maar net 1 frame per seconden (gaat wel via internet).
Ik zal het straks even via mijn LAN testen.
HSTouch
wat is je stream snelheid zonder HSTouch via internet?
Ik krijg paar beeldjes per seconden op mijn PDA binnen via 3G connectie 1024/384
HSTouch
Chak,
Hoe voeg je een RSS feed toe in HST?
HSTouch
@Wifi,
RSS is eenvoudig maar je zou het eerst een keer moeten zien..
Ik heb het van weer rss geleerd.
deze is als voorbeeld bijgevoegd.
HSTouch
deze is als voorbeeld bijgevoegd.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Ik zie hem (nog) niet.
- Jeroen Bartels
- Advanced Member
HSTouch
Chak,
Ik zou ook GRAAG bij je op cursus komen. Heb je nog plannen?
Waar kan ik overigens die zwarte toetsen vinden?
Groeten,
Jeroen
Groeten,
Jeroen
