Reading Modules from PlugwiseData.mdb
Radu
Post by Radu »
As I installed a win32 machine dedicated to PlugWise and as I want to read directly the mdb file, I am using ActivePerl via ODBC to read mainly the appliances_log table.
The point I am willing to know is wheather reading the access file (ODBC read only) may corrupt it. (As of your experience, not as general Access question ;-))I noticed some inconsistencies while polling it. (I had even to reinstall the software, some tables were illisible (once more, via the ODBC stuff)). I do not know if Access permits "consistent reads" and if my readings from the mdb may harm the genuine Plugwise update.
By the way, I already had to reinitialize two Circles, they didn't communicate any more with the others (they were relly near the others). The plugout/wait/plugin three times did the trick (as I saw on Domotica, the Dutch sentence on Plugwise site is ... in Dutch)
Regards, Radu
RC
Darwusch
Post by Darwusch »
Hi Radu,
If you don't poll more than every 30 sec you might consider copying the database file first before reading it, that way you will never corrupt the data I think.
Darwusch
Radu
Post by Radu »
Hi Darwusch,
Thank you for your reply. Yes, I arrived at this solution as I poll every minute the mdb file and I have 27 modules (The perl routine slows down and mdb file is almost constantly being used by Source Software).
Radu
RC
DJF3
Post by DJF3 »
I did the same thing for Graphs. Copying the DB every 5 minutes just to make sure the file isn't locked and I won't mess up the DB.
DJ
Reinder
Post by Reinder »
That's the best solution. Messing up the db makes the software to crash.
Return to “Plugwise Forum”
