how to record these meters
Forum about 1-Wire devices.
Woeka
Post by Woeka »
I would like to start measuring my energy, water and gas usage. However I am not sure how to do it.
I've got this energy meter:
This is how my gas meter look like:
My watermeter
I could not find any solutions for recording a "draaischijfmeter [dutch]. My gasmeter appears to have no reflecting area in any of the numbers and I also could not find any real magnetic area on my watermeter. Does anybody have an idea how to measure any of the above meters?
kind regards
Joris
b_weijenberg
Post by b_weijenberg »
Joris,
This is not 1-Wire but you can use an RFXMeter with an RFXPwr module to measure the power usage,
http://www.rfxcom.com/sensors.htm#70087
And 2 RFXPulse modules with a Reflective Optical sensors to measure gas and water usage,
http://www.rfxcom.com/sensors.htm#70090
http://www.rfxcom.com/sensors.htm#70091
To receive the RFXMeter information you need a 433.92MHz receiver
http://www.rfxcom.com/receivers.htm#80002
And sofware to process the data:
DomotiGa http://www.domoticaforum.eu/forum.asp?FORUM_ID=38
or xPL http://www.xplmonkey.com/rf.html
or HouseBot http://www.cebotics.com/
or Homeseer http://www.homeseer.com/
Bert
Alexander
Post by Alexander »
Bert,
He says he doesn't have any reflective area on the meters.
CLC
Post by CLC »
The watermeter has a reflective zone at the wheel (0.0001), right above the number 66584314.
Woeka
Post by Woeka »
Yeah, you are right. I must be able to use the CNY70 for detecting a turn of the watermeter.
Are there people who used the CNY70 for the "draaischijfmeter" also? Detecting the black non-reflecting part of the disk?
de.lesse
Post by de.lesse »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Woeka</i>
<br />Are there people who used the CNY70 for the "draaischijfmeter" also? Detecting the black non-reflecting part of the disk?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Doesn't worked here. When consuming much, it can't see the difference anymore. And is not reliable.
BTW; you can use a clamp for power measuring [:D]...
Return to “1-Wire Forum”
