Asus Eee Top
Asus Eee Top
Anyone interested in power usage of the ASUS TOP, i've put it behind a Plugwise Circle, it will be on for the next 48 hours at least:
Bastiaan
Asus Eee Top
Post by Bastiaan »
Yes I am, my one is running 24/7.
Can you check the difference with the screen on and off?
Asus Eee Top
Me to, but my Asus top is still staring at me.
Asus Eee Top
Screen on: 34.16W
Screen off: 19.19W
Bastiaan
Asus Eee Top
Post by Bastiaan »
Robert, any programs running? If you have HStouch can you check if it makes a difference when running?
Screensaver means 15watts less, ddin't expect it to be that much. Brightness fully up?
Asus Eee Top
I don't have HSTouch, not even HS, so i can't test that.
But, ehh, HSTouch is only waiting for a user to touch something and act on that right?, so how much difference would that make?
Same as Notepad running? :-) Or is HSTouch constantly interfacing with HS, even when there's no user interaction? Either way, i don't know. What i can do is look at power at full load; i'll do that.
Screen on was measured with full brightness.
With screen off i meant really switched off, as in energy saving mode off.
I will do a test with screen saver.
Bastiaan
Asus Eee Top
Post by Bastiaan »
OK clear. I was just curious if HStouch was polling a lot and if it would make a difference. My mainscreen has status indicators for a whole bunch of detectors and they react quick. Not sure if it is push or pull :-)
