X10 rain sensor
andywee
X10 rain sensor
Post by andywee »
is there anywhere else i can buy it?
Fantic
X10 rain sensor
Post by Fantic »
Go to a local electronics store, there are plenty of them in Singapore, right?
Regards, Maarten.
andywee
X10 rain sensor
Post by andywee »
eh, I bought 2 PCB from an online store. something called leaf wet sensor. well. it works good except that when it already stop raining, the sensor is still wet and it takes like almost 1hr before it triggers a "dry" sensor state.
b_weijenberg
X10 rain sensor
Post by b_weijenberg »
that's why those sensors need to have a heating element below the PCB.
Peterpc
X10 rain sensor
Post by Peterpc »
Place it 45 degrees, water will drop off.
Wima
X10 rain sensor
Post by Wima »
I did installed one with heating element. Low cost and works great with the Marmitek SM10
http://shop.conrad.nl/elektronica-meeta ... 87608.html
Wil
Even the genious ask questions.
Esteban
X10 rain sensor
Post by Esteban »
Mounting it at 45 degrees is a must indeed for the water to roll off it. You don't want it to just form a little pool on there.
@wima: do you also heat it too? because thats not done then with a sm10 right
@Snelvuur: The heating element is built into the sensor. This is powered via an external power source. The SM10 is just mounted to the relais the sensor has.
DJF3
X10 rain sensor
Post by DJF3 »
Do you think it would be possible to use the a Visonic MCT-100 and the Conrad rainsensor? (it has a 'potentiaalvrije schakeluitgang')
So the alternative is an SM-10 with the Kemo M152?
Thanks!
DJ
Esteban
X10 rain sensor
Post by Esteban »
Originally posted by DJF3-2: So the alternative is an SM-10 with the Kemo M152?
Or a DS90
Snelvuur
X10 rain sensor
Post by Snelvuur »
@estaban: yes that part i understand, but you keep it "warmed" 24/7? it has a trigger no?
Esteban
X10 rain sensor
Post by Esteban »
Originally posted by snelvuur: but you keep it "warmed" 24/7? it has a trigger no?
Yes, it only is heated up when rain is detected, the rest of the time the heater is off.
Snelvuur
X10 rain sensor
Post by Snelvuur »
thats pretty handy :p time to order one at some point.. :)
Henk
X10 rain sensor
Post by Henk »
There is another rainsensor in the Conrad shop check number 156515 I think it is only a remote sensor and it will not include the alarm circuit ....
Henk
DJF3
X10 rain sensor
Post by DJF3 »
Is it possible to use the a Visonic MCT-100 with the Conrad <i>OR</i> Kemo M152 rainsensor? (it has a 'potentiaalvrije schakeluitgang')
Bye
DJ
SNG
X10 rain sensor
Post by SNG »
my windows are casement non cranked type. and nope i wish i can change my windows. the government doesn't allow other types of windows except friction stop casement windows and sliding windows. not complying to regulations results in confiscation of house. yeah. that's the law in singapore
What kind of windows you prefer to use then?
Think that the rules about renovating in Singapore are the same as in Holland or even looser. When you live in subsided public housing (HDB) or a Condo you are bound to much more restrictions then with private properties. With landed private properties you can build what you want, in Holland is that only possible in the free sectors. A permission you can get it here within a week or two, in Holland my sis needed to wait for 5 months to make an little addition to her kitchen. Try in Holland to change the colors of your window or front door of a 'woningbouw' (public housing) house. A friend of mine did that and he got a notice from the authorities to change it immediately back or he has to move out! In Singapore you can change at least the colors of your windows and get a different front door. Just a note...
For the rain...I use a humidity sensor, Singapore has always a very high humidity around 75% and before it start to rain, it climbs very rapidly to 85% or higher. Combine it even with a light sensor for during daytime, sky suddenly darker and humidity raise, rain :) Getting lighter and humidity drops slowly, dry again :) Tropical rain showers are very easy to predict...
check also hunterindustries.com/Support/Installati ... truct.html
Thunderstorms are in Singapore more frequent and heavier then in Europe, especially during the raining season. To protect my equipment I am building now a lighting sensor so shut down some equipment when the lighting gets to close...
