New version Plugwise Source V20090620.0 released!
You can change the type of an appliance via de 'apparaten' display. Select an appliance that you want to change. At the bottom there is a select box, with the current type selected. Select another type and there you go.
I have done the upgrade...don't see what the problem is.
All is working fine including webserver and HS connection.
[img]uploaded/Chak/2009611204939_plugver.png[/img]
Ruud
Post by Ruud »
Still got sometimes tis error.
Hs and plugwise on the same pc!
13-6-2009 11:45:56 Plugwise ERROR: Cannot query http://localhost:8080/statistics.xml: Kan geen gegevens lezen uit de transportverbinding: De externe host heeft een verbinding verbroken.
Edwin2008
Post by Edwin2008 »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rualblas</i>
<br />Still got sometimes tis error.
en geen error's in windows system log?
Ruud
Post by Ruud »
Alleen deze melding heel vaak.
Maar die van plugwise 1 keer in een uur
Type gebeurtenis: Fout
Bron van gebeurtenis: Userenv
Categorie van gebeurtenis: Geen
Gebeurtenis-ID: 1041
Datum: 28-5-2009
Tijd: 19:05:53
Gebruiker: NT AUTHORITY\SYSTEM
Computer: HOMSEERLAPTOP
Beschrijving:
Kan de registervermelding DllName voor {7B849a69-220F-451E-B3FE-2CB811AF94AE} niet opvragen. Deze wordt niet geladen. Mogelijke oorzaak: een foutieve registratie.
I did the upgrade to the latest plugwise version and everything worked OK for me. Even my Bwired home brewed interface with the source software worked immediately :-)
I also see that the upload of user data is changed by plugwise, now you can choose if you want to upload the data to plugwise.
The only downside to that is that you have no support anymore? (see below), hopefully they will change this also very soon, I think they have to maintain the support!
@rualblas: I do think it is something in your setup. For me it is working OK, never seen that error while the Source was running.
Jeroen Bartels
Post by Jeroen Bartels »
What is the benefit of upgrading!?
All is working fine with the original installation files and plugwise plugin by Rene.
Or did I miss some important improvements?
A lot of things are fixed, depends on which version you are running now.
One of the important one is the 0 watt bug while a device is running.
Check the topics for all the changes.
cedriclocqueneux
Post by cedriclocqueneux »
And where are other translations ? I made french translation for you, but in the last version, i have always english and nederlands :(
jheerink
Post by jheerink »
Not totally bug free yet, I,ve got 2 plugs now indicating a total use of serveral million watts, but after a reset finally it was ok again
I also experienced strange things. Some plugs did not report anything, others were offline. After restarting the Source everything recovered.
Alexander
Post by Alexander »
@jheerink: that was also with the past version: http://www.domoticaforum.eu/topic.asp?TOPIC_ID=2332. So not solved ;-)
jheerink
Post by jheerink »
Mmm, it keeps coming back So the gathered data
are more or less useless now. any clues how to solve
this ? Exept form reinstalling. (One of the incorrect
plugs is the Circle+, 2 out of 46 are irratic)
I have some problems recurring almost everyday and which are solved by restarting the Source. Some appliances are no longer updating the usage history statistics while the current statistics are OK. The status of these appliances is OK when looking in the source (they have a bright bulb as icon), however when you use the webinterface, these appliances have a question mark as icon meaning the status is unknown. Because the Homeseer plugin uses the web interface of the Source, the status is incorrect here too. When I restart the source everything recovers and the historic data is updated.
Return to “Plugwise Forum”
