New version Plugwise Source V20090620.0 released!
- Member
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rklootwijk</i>
<br />I have some problems recurring almost everyday and which are solved by restarting the Source. Some appliances are no longer updating the usage history statistics while the current statistics are OK. The status of these appliances is OK when looking in the source (they have a bright bulb as icon), however when you use the webinterface, these appliances have a question mark as icon meaning the status is unknown. Because the Homeseer plugin uses the web interface of the Source, the status is incorrect here too. When I restart the source everything recovers and the historic data is updated.
I am experiencing exactly the same problems. Looks like I have this problem since the latest update.
This problem also started for me after the last update 20090612.
Same problem here. It's always the same 2 plugs that won't update. Switching them on or off by homeseer isn't possible at that time. Restarting the source and the problems are gone.
Switching the appliances when the problem occurs does work for me (at least from within the Source, not from within Homeseer becuase the status is unknown here).
after update, the source take a long time to see the circle's. And some circle's behave strange.
FYI: I checked my version V20090606.3 and this one is still updating the totals.
And again the problem occurred. Again and again no historic usage data is shown for the same 3 circles and the circles have status unknown in the web interface while the Source shows them being allright (except for the historic data).
Latest version is V20090620.0
With this version, I don't have problems.
- Member
Yesterday I upgraded to V20090620.0 but unfortunately this doesn't seem to help.
In the previous version I had 3 circles that showed the problem. In this version only one of the 3 remains showing the problem. So something has changed but the problem has not been changed.
A few hours later the problem solved itself. Let's see how it behaves the next days.
Well, this is exactly the problem that I have with the source: you never know if it's still busy collecting data, or that it is done:
- When you start up the source and click on modules you will see some modules showing no usage at all, while others are showing usage. It would be much better, for those modules it has not
completed datacollection yet, that it shows work in progress, or incomplete data.
- The same applies to the timeframe displayed, if one selects 2 weeks of history, the incomplete modules might be still showing a single day, while the ones that are finsihed are showing the entire 2 weeks. IT would be much better if it showed the same timeframe for both instances.
When the source and de stick are communicating, The time displayed is strange. Like microsoft
for 10-20 sec it's say's 2 sec enz
Gr Ruud
Gr Ruud
3 days ago I upgraded to V20090620 and until now all is working fine now.
Here also running 3 weeks now without any problem.
Today added 10 new plugs to the configuration.
- Antoon
<h6>
- Antoon
<h6>
