Included Popp wireless wall switch in HS
- Member
Mmmm......... no, not that way we should like it Chak
maybe we should ask Rick to do something in the new beta, or maybe a way to create virtual zwave devices in HS, that should do the trick. Or.... in the beta there are already things which I do not know of, I'm still running 2.3.0.19. I wonder if that batterystatus will apear in the beta. Till now I'am a bit anxious tho install the beta. What is you experiance till now Chak?
<br />Willem,
thats good News.
Can you now trigger events?
<br />Willem,
thats good News.
I'm running the latest beta .117 (some small problems lefts in this version)
I don't own the switch ..since there was no support for it.
I hope HS will add some extra options for this device.
This can be one of the best remotes for HS..![Smile :)](./images/smilies/icon_smile.gif)
I am pretty sure this would activate scenes i HomeSeer (It does in Vera.)http://www.homee.dk/index.php/en/produk ... urer_id=16 but it is the last ones Innovus is gone.
I would expect this to work to http://www.homee.dk/index.php/en/produk ... urer_id=15 but I haven't tried one yet. It will be on the marked soon.
The one form Qees looks a bit bigger the the Popp version.
The Qees is about half the size of the Popp, it is realy small.
It's Danish standard.
Let's make z-wave EZ
You can compare size here. http://zwaves.dk/forum/viewtopic.php?f=21&t=311
(Forget or translate the Danish.
![Smile :-)](./images/smilies/icon_smile.gif)
We made some mods with z-ring http://www.innovus.dk/index.php?id=142
http://zwaves.dk/forum/viewtopic.php?f=7&t=20
Maybe you can do the same with QEES ring? http://www.homee.dk/index.php/en/produk ... urer_id=15
- Member
Well, the product look good, but I can not [:(] understand anything off it [V]
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mhn</i>
<br />We made some mods with z-ring http://www.innovus.dk/index.php?id=142
I try to understand some of your Dutch with Google translations. ![Wink ;-)](./images/smilies/icon_wink.gif)
Z-Ring is Innovus and gone. But I guess QEES ring will be close to it.
@mhn
thanks for the info.
looks nice.
Qees ring is indeed a good solution for moding.
looks nice.
The only imported text is the text for the 2 upper pictures.
Forget the way I write at the bottom here is a very fast and more easy way.
There are only five wires and they don't need to be soldered on LK switch.
Here you can see in a Closeup.
The 4 inner wires placed on each of their contacts down to LK and the last which is ground into the earth LK
The QEES wall description is in Danish. I hadn't noticed.
But Documents is in English: http://www.homee.dk/index.php/en/produk ... uct_id=105
