Limited number RFXio Digital I/O available
Moderator: b_weijenberg
b_weijenberg
Post by b_weijenberg »
I have a few assembled and unassembled RFXio Digital I/O sets available. Send me a PM if you want more technical and pricing details.
The RFXio is supported by the beta plug-in version 14.0.0.18 which is available for download on request.
The RFXio Digital I/O interface has up to 8 Input-Output lines. Each line can be configured to be used as an Output using a relay contact or to be used as an Input using the opto-coupler.
The 1 port RFXCOM LAN interface has 2 I/O lines available.
The 2 port RFXCOM LAN and WLAN interfaces have 8 I/O lines available.
The RFXio Digital I/O interface must be connected to a RFXCOM Ethernet interface with a 14 wire ribbon cable.
Important: The 14 wire ribbon cable must be soldered to the RFXCOM Ethernet interface by a person that has soldering skills.
Bert
Arjen
Post by Arjen »
Hi Bert,
I'm interested, but cannot send you a PM, please PM me about this.
thanx
Arjen
iamjwk
Post by iamjwk »
Bert,
Can you send me the details so I can think if this would be interesting for me? Also cannot send pm yet.
Jan-Willem
Willem4ever
Post by Willem4ever »
Bert, are the "white" components the relays ?? they seem (very) small can your share he specifications with us . Thanks ..
b_weijenberg
esschenk
Post by esschenk »
Recently I am in possession of an interface RFXio
Its working fine
The only thing not working is a short pulse on the input that is not seen
Because the input is polt.
This was solved by making a puls extender.
Now it works even with a very fast pulse, example off the doorbell.
http://www.domotica.famschenk.eu/RFXio_Timer.html
Ps.you can also use this for the IPPower
Ed
Edwin2008
Post by Edwin2008 »
From the diagram you don't use the reset button and the 0,01uF, right?
Trigger is the doorbell button and output is going directly to the input of the RFXio.
** edwin **
esschenk
Post by esschenk »
Hello Edwin,
Thats correct,
If you want to use also your existing doorbell then you must use a relay to the input of the timer.
Ed
