New release Plugwise Source 2.0.1 Final, Release 20091021
jheerink
Post by jheerink »
What did,nt work today was the message that i should schedules send again due to wintertime.I read that that was supposed to be a new feature in the latest version.
It did however make a connection with a plug that had been unreachable for several weeks. With the new version it immediately got updated. The previous version had a problem with that plug.
petermdevries
Post by petermdevries »
Same situation here. Sometimes it takes up to a few seconds before plugs are responding to a on/off command from Homeseer. Nevertheless I am very happy that all plugs are now at least responding correctly via the Webserver (and HomeSeer Plugin). Since I've updated Source last friday all plugs have been responding.
Also the response from the plugwise software is very slow.
Is there a possibility to install the previous version again?
Turn on will take sometimes more than 10 seconds.
Antoon
Post by Antoon »
I updated this morning and after 12 hours running everything is working fine.
I am not notice any problems with the response.
Plugs are switching within 1-2 seconds
- Antoon
Reinder
Post by Reinder »
As I now, there is no reported problem about slow response.
@chak/peter
Could you pleas check if all your appliances are reachable/on-line in your Source? Because this version of the Source is trying 'harder' to reach all the appliances (higher priority) this could slow down other processes.
Please mark the non reachable appliances (unplugged) in the Source offline: Go to Settings->Appliances and mark "temporarily not in network"
Bastiaan
Post by Bastiaan »
I have tested my system for responses:
Sometimes it reacts within a second but too frequent the switching takes >10 seconds.
I can do an on/off a few times, then the plug will excute all the commands 10 second later al quickly after each other.
Dickr43
Post by Dickr43 »
Same problem here since the update. Also one plug unreachable from HS, can be reached from Source though. The response from the Source software is OK, have not had any delays from there yet.
@dickr43: You mention one plug is unreachable from the Homeseer while it is OK within the Source. Can you check what the output for this plug is when you query statistics.xml from within a browser?
Dickr43
Post by Dickr43 »
Rene, what is the query statement again?
petermdevries
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Reinder</i>
<br />As I now, there is no reported problem about slow response.
@chak/peter
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">All plugs are reachable and online according to Source (looking in Apparaten).
@dickr43: http://<the host running the Source>/statistics.xml
Dickr43
Post by Dickr43 »
@rklootwijk:
Output is:
<appliance>
  <id>8</id>
  <name>Vloerlamp TV</name>
  <type>Lamp</type>
  <image>/pwimg/32/lamp_unknown.png</image>
  <locked>False</locked>
  <realstate>unknown</realstate>
  <powerstate>unknown</powerstate>
  <powerusage>0</powerusage>
  <totalusage>1475</totalusage>
  <moduleid>9</moduleid>
  <macaddr>000D6F00003848A7</macaddr>
  <moduletype>Circle</moduletype>
  <room>Woonkamer</room>
  </appliance>
Hoop dat je er iets in ziet!
Deze regels geven aan dat de status onbekend is. Het komt dus bij de Source vandaan en zit niet in de plugin (maar dat wist ik al ;-) ): Het lijkt op het probleem wat in de vorige versie zat. Wat gebeurd er op het moment dat je in de Source de eigenschappen van het betreffende device opvraag? Als het goed is wordt het device door de opvraag expliciet gepolled en het huidig verbruik opgehaald. Als je dan weer een query doet op statistics.xml ben ik benieuwd wat de status is. Als dit dan weer werkt lijkt het probleem van de vorige versie niet helemaal gefixed te zijn.
Voor de zekerheid, kan je de versie van de source controleren?
Dickr43
Post by Dickr43 »
Na een keer schakelen vanuit de Source krijg ik deze output:
<appliance>
  <id>8</id>
  <type>Lamp</type>
  <image>/pwimg/32/lamp_off.png</image>
  <realstate>off</realstate>
  <powerstate>off</powerstate>
  </appliance>
  </items>
De versie is V2009.1021.2
Dickr43
Post by Dickr43 »
Sorry Guys,
Forgot about the language... I think I got it working again! Moved house this week and the distance between the circles increased. Just placed an unused circle between two (a bit far apart) circles and now it looks like the network is OK again.
Seems like the distance between circles should not be more than 4 meters.
Return to “Plugwise Forum”
