Domotiga is very great, thanks for such an nice program.
I started to translate it in German , it work but where in the code is the language file so i can give it to you?
During the process of translating i found out that not all words could be translated, because of being in the database, or hardcoded.
I see you working on that.
I'am not so good in coding, i modified the barcode tool, so that it will do with an pac 207 webcam as barcode scanner, by using the zbarcam tool from sourceforge. I'am sorry it's only hardcoded(nice word
Bugs i have ... with the 0.1.172
The camera device will open to my pac 207 webcam, but show no picture or video . If i insert the gambas example for webcams , the example will work.
If i use my 1 wire dallas temp sensors for outside temperature only whitout humidity domotiga will breakdown whith an error, i fixed it by giving the sensor an static humidity.
I dont got the webclient to run, but that could be my bad configuration.
thanks for domotiga.
Domotiga is great very good work!!
Greetings TSA
