Qees Power and Qees Dimmer
Willem4ever
Post by Willem4ever »
Can anyone report these devices to work properly with homeseer ?
mhn
Post by mhn »
I haven't tried QEES Dimmer yet. I don't think it is on the market.
elmstrom on zwaves.dk have tried QEES Power with Homeseer with luck.
Maybe you can use this with Google translate: http://zwaves.dk/forum/viewtopic.php?f= ... 2662#p2662
Regards
Morten
EzHome
Post by EzHome »
Qees Power is on the market now and works fine with HS, dimmer takes
about 4 weeks to be released.
Let's make z-wave EZ
Willem4ever
@ezhome: Can you extract the power meter readings from the Qees Power with HS ?
mhn
Post by mhn »
From elmstroms post on zwaves.dk:
Have tested with HomeSeer:
Works, On/Off, Watt og Watt/hour
EzHome
Post by EzHome »
Yes you can extract the power meter as well in Homeseer as in Vera.
If the device is switched local the status is pushed to the controller within seconds.
Willem4ever
thanks guys, this seems an interesting device!
jakkes
Post by jakkes »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ezHome</i>
This is something that i miss on the Plugwise devices!!!
phoenixb
Re: Qees Power and Qees Dimmer
Post by phoenixb »
have some one already test or used it on HS.
Because i'm intressting the Qees Power as alternative for de plugwise.
__________________
Mversluis
Post by Mversluis »
Last time i Speak with Willem-Jan ( ezhome ) and he was testing the cees power , but only within vera.
Maby you can ask him.
Sometimes he is on the forum here.
Marco
mhn
Post by mhn »
elmstrom on zwaves.dk has tried it with HomeSeer.
In this thread http://zwaves.dk/forum/viewtopic.php?f=26&t=510" onclick="window.open(this.href);return false; he writes works, on/off, Watt and Watt/hour.
It should be 100 % Z-Wave.
The manual is now on http://www.qees.eu/brugermanuler-3/" onclick="window.open(this.href);return false;
Regards
Morten
SeRo
Post by SeRo »
Is there anyone how has tried the Dimmer version?
Or is it still not available?
mhn
Post by mhn »
The Dimmer version is not available yet.
QEES says, it will be at the beginning of June. There is still some certificates missing.
Return to “Z-Wave Forum”
