RFXCOM receiver for Electrisave / cent-a-meter
Moderator: b_weijenberg
b_weijenberg
Post by b_weijenberg »
The RFXCOM USB X10/Oregon/KlikOn-KlikOff/Domia Light receiver is able
to receive also the Electrisave (cent-a-meter) RF data. http://www.rfxcom.com
Some explination on the Electrisave versus the RFXPower:
The Electrisave measures the current of up to 3 phases. Using the
RFXCOM receiver the received data can be logged to the PC and the
data can be used to create graphs of the power usage.
In the standard Electrisave configuration the measured current will
transmitted to a display unit where the current (ampere) value is
multiplied by a fixed voltage parameter. It displays then the power
usage for that single moment. But the displayed power value is not
very accurate because the voltage is a fixed parameter in the display
unit while the real line voltage fluctuates a lot. So it is not a
real power usage meter but in fact an Ampere meter.
The RFXPower measures the real power of 1 phase by multiplying the
measured current times the measured voltage. The internal kWh counter
in the RFXPower unit is increment for each use of 10Watt and is
therefore comparable with the utility meter.
Connoleg has written software to show the power usage in Homeseer:
http://board.homeseer.com/showpost.php? ... stcount=61
Bert
Here is an example trace of data received by the RFXCOM receiver from
X10, Domia Light, RFXPower, RFXSensor, Visonic (=BT VP1000) ,Oregon
sensors and the Electrisave:
50EA4C1027601650130000 THWR288N Water sensor CH 1 addr:27 temp:+16,6°C / 61,88°F bits=80
3007F7C6E69201 RFXMeter addr:07F7/2039 RFXMeter: 9619174; RFXPower: 96191,74 kWh; RFXPower-Module: 9619,174 kWh bits=48
500A4D100A802000002600 THR128 Inside Temp CH 1 addr:05 temp:+20,8° C / 69,44°F bits=80
20906F20DF F1-Off bits=32
503A0D00E014052020012D STR918 Anemometer direction 51° NE speed 2 m/sec 2 Bft av. speed 1,2 m/sec 1 Bft battery 60% bits=80
503A0D00E0100520200129 STR918 Anemometer direction 51° NE speed 2 m/sec 2 Bft av. speed 1,2 m/sec 1 Bft battery 100% full bits=80
78EA00A3000000000D86FF5F1D601400 cent-a-meter addr:A3 counter:0 CT1:0 Ampere CT2:0 Ampere CT3:0 Ampere bits=120
503A0D00E0440520200130 STR918 Anemometer direction 54° NE speed 2 m/sec 2 Bft av. speed 1,2 m/sec 1 Bft battery 60% bits=80
503A0D00E040052020012C STR918 Anemometer direction 54° NE speed 2 m/sec 2 Bft av. speed 1,2 m/sec 1 Bft battery 100% full bits=80
503A0D00E0440523200133 STR918 Anemometer direction 54° NE speed 2,3 m/sec 2 Bft av. speed 1,2 m/sec 1 Bft battery 60% bits=80
503A0D00E040052320012F STR918 Anemometer direction 54° NE speed 2,3 m/sec 2 Bft av. speed 1,2 m/sec 1 Bft battery 100% full bits=80
2C186B23161520 Digimax addr:186B/27416 Temp>=Set Temp:22 Set:21 bits=44
500A4D100A902000002700 THR128 Inside Temp CH 1 addr:05 temp:+20,9° C / 69,62°F bits=80
78EA04A35200000018FAFF5F9D60540A cent-a-meter addr:A3 counter:4 CT1:8,2 Ampere CT2:0 Ampere CT3:0 Ampere bits=120
501A2D10A42115702536D0 THGR228N Inside Temp-Hygro CH 1 addr:A4 temp:+15,2°C / 59,36°F hum:57 Normal bits=80
503A0D00E0640723000236 STR918 Anemometer direction 76° ENE speed 2,3 m/sec 2 Bft av. speed 2 m/sec 2 Bft battery 60% bits=80
503A0D00E0600723000232 STR918 Anemometer direction 76° ENE speed 2,3 m/sec 2 Bft av. speed 2 m/sec 2 Bft battery 100% full bits=80
3008F809C60005 RFXMeter addr:08F8/2296 RFXMeter: 2502; RFXPower: 25,02 kWh; RFXPower-Module: 2,502 kWh bits=48
29D1DE847B5480 Visonic or DS10/90 Normal addr:D1DE 54/31627 bits=41
2024D40AE0 RFXSensor addr:24D4/9428 Temp:10,875 ºC bits=32
John Downe
Post by John Downe »
I suspected and hoped you would include this Bert - thanks - I now cannot resist any more buying one of your receivers! Going there now to order! Of course I may then end up getting a RFXPower, but this will do for now.
JWD
Re: RFXCOM receiver for Electrisave / cent-a-meter
Bert,
While desperately searching why my HS system eats up 100% CPU i noticed this one in RFXreciever.
14-11-2010 18:41:46= 781A2905550A4041F15747F187070000 bits=120
14-11-2010 18:41:46= 6CEA28FEF00000000000000060AF07 ELEC1[65024] cent-a-meter addr:FE counter:8 CT1:24 Ampere CT2:0 Ampere CT3:0 Ampere Checksum Error bits=108
I got a reading of cent-a-meter while there is none anywhere near in or outside my house.
This is probaly a faulty reading, right?
b_weijenberg
This is indeed a feulty received packet. Some bytes indicate a ELEC packet but the checksum indecates that the packet is not OK and will be skipped.
