i am gona measuring the power that our solar pv panels produce.
is it posible to add an extra chart and loging to the rfx plugin
can i simply add a few lines to the script that runs every 60 minutes
add a solar chart to the rfx plugin
Moderator: b_weijenberg
I would be interested in this as well. Maybe it's better if this could be officially supported in the rfx plugin? Bert, any chances that you'd be building this in sometime in the future? Maybe it would be nice to be able to compare solar pv output to the Oregon uv-sensor readings (in the same graph?).
Lennart
Lennart
- b_weijenberg
- Forum Moderator
If you use the RFXMeter for power measuring it is not so difficult.
select an unused chart indicator at the devices, for example 3.
Copy and modify the RFXUtilty.aspx in the html\RFXUser directory.
