This is the solid-state drive that we've been waiting for: a full 256GB, which Samsung says is "the world's fastest and largest capacity 2.5-inch, MLC-based SSD with SATA II Interface." Sick sequential read and sequential write speeds of 200 and 160 MBps, respectively, put it in the same speed range of more nimble single-level cell SSDs (single vs. multi-level explained). Available in Sept. with mass production starting by "year end" (yay cheaperness), and Sammy says we'll see a 1.8-inch version by then too
With a sequential read speed of 200 megabytes per second (MB/s) and sequential write speed of 160MB/s, Samsung's MLC-based 2.5-inch 256GB SSD is about 2.4 times faster than a typical HDD. Furthermore, the new 256GB SSD is only 9.5millimeters (mm) thick, and measures 100.3x69.85 mm.
