<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Katsie</i>
i don't see any prices on the WWW.
next to that, the ports for sensor, i can use a IR sensor for it ( ''perretje? '')
and just 1 BNC in i see, could it be splitted or so , to 2?
and can i use otter cams with it?
sorry for the amount of qeustions
and next to that, what i don't see in the manuel, or on the webeye website, it means i can acces it with just in IP adres, like an IP camera?
P.S. voor de nederlanders onder hier, als in koop over ga, misschien iemand interesse om te helpen met opzetten van instellingen etc, voor een vergoeding?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
You can find more on the WebEye here:
http://www.webgateinc.com/wgi_htdocs/en ... _eng&no=12
It's basically a box that converts any video camera into an IP camera. It has both a composite video input as well as an output, so you could plug it in between an existing camera and monitor. It can be used with only one camera. It has a number of serial ports, supporting a big number of pan/tilt/zoom cameras and a couple of audio converters. It even has 4 digital inputs which you could connect to a PIR sensor, a door switch or even your doorbell to direct the camera at a preset position and send you an email with a photo if it is triggered.
I'm quite happy with them, though I'm not too satisfied with motion detection and the lack of JPG. Instead they use wavelet compression which is very common in the security industry because of it's high compression rate without lost of details. They offer plug-ins for many platform, but still I'd rather would have had JPG.
We're all hobbyists here; We'll help you out when things need to be set up.
advice IP cam
Moderator: Esteban
- Advanced Member
- Contact:
advice IP cam
mindbender, gave me some acces to his Webeye 101 , its works great, very easy to use, as what i saw, his cam rocks as well, great vieuws during the night, and day.
but next to that, i also have an Bosch Dinion XF cam, ( bnc ), i can use it also with the video server? , not for zoom etc because i got prime lenses. (just to make IP )
and also got an BNC eneo camera.
Losmandy G-11 | eos 1D 1+ | 350D 1+ | LX90 8'' | SV 102 apo | lenzen |
Eneo cam
| Bosch Dinion XF kleur camera | en opzoek naar ip cam
Eneo cam
advice IP cam
<br />mindbender, gave me some acces to his Webeye 101 , its works great, very easy to use, as what i saw, his cam rocks as well, great vieuws during the night, and day.
Eneo cam
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">got enough information
''Integration with any existing analogue CCTV camera for remote survellance''
Eneo cam
Eneo cam
Eneo cam
advice IP cam
we are a few days further, bought an webeye B101 from Mindbender, i need to say, i am impressed about how easy it works, now my Boscg XF dinion XF is on it, and the view looks pretty good, the Bosch is USB controlled so cant controll is with the webeye then, but i like it already,when i got the final outgoing link, i will show the link.
its on a box front of my window so no good view.
kindly regards, erwin
Eneo cam
Eneo cam
