This led flexible strip has basically the same specifications as our non waterproof RGB Led strip except beeing produced at IP67 (waterproof) standarts. Led's will have the same brightness as the normal RGB!
It can be still cut on every 3 led's (100mm) but the IP67 will need to be retained by the installer using waterproof silicon (at the point that will be cut).
http://www.hiline-lighting.com/pd-rgb-l ... meters.cfm
RGB Led strip IP67 5 Meters
Hi Hiline,
Can you tell us something about the protocol used for the Wireless RGB Led Strip Controller (R/F)?
Unfortunately we do not have any detailed information on the protocol used for the wireless communication between the remote and receiver.
From what I know the frequency of communication is 315Mhz and encoding/decoding is one way digital. The range of operation can be up to 30 meters but antenna of the remote must be extended if you move more than 10 meters distance from the receiver.
I hope my answer can solve some of your questions.
