How many address are there per sensor en a key fob.
I think that i had discovered all my sensors, but the number of address is growing!!! There are no neighbors with visonic.
And give the powermax also a address?
greetz Ruud
Visonic sensors address
Moderator: b_weijenberg
@Ruud
Per device there is only one address
Powermax self has no address
- b_weijenberg
- Forum Moderator
A Visonic door sensor can have 2 addresses. One for the reed contact and one for the aux contact.
The aux contact can be used as alarm contact for another door or window or it can be used as a non-alarm contact for example for the postbox or a door chime.
(Put the 47k resistor over the door chime button contact.)
Bert,
That simple? parallel over the pushbutton. No problem with the current 9 or 12V?
grtz Ruud
grtz Ruud
- b_weijenberg
- Forum Moderator
It must be a dry-contact. So a contact without any voltage on it!!!!
Visonic address that are not my. Can i put them put them as detect but ignored? . Now they use a code from the list and it's going fast.
- b_weijenberg
- Forum Moderator
Ruud,
You can simply ignore sensors that are not owned by you.
before adding a sensor clear the sensors heard list, then activate the new sensor and hopefully you will find only one sensor in the list to add.
Bert
Bert
