DMX moodlight panel
Moderator: Mversluis
Snelvuur
DMX moodlight panel
Post by Snelvuur »
http://www.plsshop.nl/offers.asp
249,- euro de stuk zijn ze nu. (dus in de aanbieding)
Als je nog wilde spelen ermee ..
http://www.plsshop.nl/detail.asp?pid=VM116&cat=306
USB Aansturing (119,- euro)
Lennart
DMX moodlight panel
Post by Lennart »
But be careful:
These are not the Traxon moodlight panels as mentioned in http://www.domoticaforum.eu/topic.asp?TOPIC_ID=313. Given its power consumption, this panel must be less bright than the Traxon version (9,6 Watt versus 15 Watt).
Note that Traxon is a well known supplier of quality LED lighting, whereas I've never heard of ELD before (and their products look very familiar as in Chinese OEM-stuff relabeled to whatever brand you want).
On the other hand, this one has a remote control and some chases / programs built in. There's no remote control included with the Traxon DMX version (only with the RF and IR versions).
I'm wondering how these work: control the individual colors with DMX-addresses and one additional DMX address for program selection (to be used if individual color control is not needed/wanted)? (This is the way many LED-tubes work.) Or would there be a switch on the panel that says either "DMX control" or "Remote control"?
Lennart
Snelvuur
DMX moodlight panel
Post by Snelvuur »
I think i'll get a set next month to try out. The "example" pictures look nice, i know the person that sells these and he told me that there easy to control and looks nice too. (ofcourse every sales person will tell you this, but he's an online person too) if i get this, and i will at some point. I will keep everyone up to date.
Mhwlng
DMX moodlight panel
Post by Mhwlng »
<br />I think i'll get a set next month to try out<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I see :
Einde aanbieding: 30-11-2007
Nog 5 dagen resterend
I also don't see the traxon panels for sale anymore at Bax Light & Sound shop
also, if you have multiple panels, I assume that you need to build/get your own single 12V power supply (I assume that each panel comes with a small 'wall-wart' ?)
Marcel
Snelvuur
DMX moodlight panel
Post by Snelvuur »
Yeah i know, money is up for this month.. ;)
Lennart
DMX moodlight panel
Post by Lennart »
Try http://www.barndoor.nl/moodlight.html for a Dutch Traxon supplier. The classic DMX panel is EUR 290 ex. VAT (BTW).
Lennart
Snelvuur
DMX moodlight panel
Post by Snelvuur »
Lennart, is there any difference with the usb device? I was going to use your perl script on it :)
Lennart
DMX moodlight panel
Post by Lennart »
Hi Snelvuur,
Yes, odds are that this interface is different from the Enttec USB Pro interface, as far as the serial protocol between PC and USB interface is concerned. Note that, of course, both devices "speak" DMX, so on the DMX cable the protocol is the same, but there is unfortunately no standard for the communication between PC and DMX controller, except that it uses USB/RS232.
The nice thing about the Enttec controller is that this part of the communication is quite simple and resembles the DMX protocol itself. I don't know the DMX controller in your posting, so I wouldn't know how different/difficult it would be, but don't expect to run my script "out of the box".
Lennart
Mhwlng
DMX moodlight panel
Post by Mhwlng »
I connected 4 panels to one of these
http://www.lanbox.com/products/LCEDataSheet.html
The nice thing about the lanbox is, that it can work 'stand alone'.
I.e. you define some cuelists, that can contain animations, (cross)fades, chases etc.
and then you can simply start a cue via ethernet tcp/ip (I use girder).
So, you don't need to animate each channel over time (although, you can)
for example, I made a simple cuelist that slowly brightens the panels from 'off' to 'full on white' in 15 minutes, to replicate this :
http://www.wakeuplight.philips.com
note that these are the same panels :
http://www.hqpower.com/product/view/?lang=en&id=368110
or (not 100% the same)
http://www.chauvetlighting.com/fixtures ... _fix.shtml
note that I've seen versions :
-with/without microphone
-with/without dmx address dipswitches/DMX adress LED display
Marcel
Snelvuur
DMX moodlight panel
Post by Snelvuur »
@marcel, did you import those dmx panels? Seems like you have some different ones too. These have a grey surrounding, while the ones from plsshop is white (http://www.plsshop.nl/detail.asp?pid=ELDML001&cat=251) and the ones from the link of lennart (http://www.barndoor.nl/moodlight.html) are black surrounding.
Also, did you import the lanbox? Since my problem with having dmx was because you have to place the cable through the house, which is not so real handy to do.
Mhwlng
DMX moodlight panel
Post by Mhwlng »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">did you import those dmx panels? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
no, I got them from plsshop.nl, for the special offer price that you started this post with...
they have the hqpower logo on them (see above link)....
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Also, did you import the lanbox? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
no, they are made by a dutch company, see above link
Marcel
Lennart
DMX moodlight panel
Post by Lennart »
Hi Erik and Marcel,
Just a note: the classic Traxon moodlight panels that I have (as sold by barndoor) have a grey aluminium frame, not black.
Furthermore: the Lanbox-LCE seems to be *very* interesting, especially as it can be used stand-alone (using TCP/IP to change programs if you like) as well as controlled directly with a DMX over Ethernet (using UDP) signal. I'm ready to order one :-). I just noted the very steep shipping costs: 45 euros for a parcel within the Netherlands? Marcel, did you have to pay this?
If you have the Lanbox, the following device - Solarox DMX RGB stripe controller - is quite interesting as well, if you also happen to like LED strip lighting:
http://www.led1.de/shop/product_info.ph ... arox-p-507
Gamma had some Philips LED strips on offer, a few weeks ago. I bought one RGB version to play around with. I cut off the Philips (braindead) controller+cable and connected the strip to the Solarox, using the Philips power supply. It works pretty well :-).
Lennart
Mhwlng
DMX moodlight panel
Post by Mhwlng »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> I just noted the very steep shipping costs: 45 euros for a parcel within the Netherlands? Marcel, did you have to pay this?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">this is on my invoice :
QTY   PRODUCT              AMOUNT
  1     LanBox-LCE           295.00
        Shipping/handling:    25.00
        Value Added Tax:      60.80
        Total amount:        380.80 Euro
It was shipped via HL Couriers
Marcel
Mhwlng
DMX moodlight panel
Post by Mhwlng »
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">here's a big assortment (dutch language only!) directly from China :
http://www.samenkopen.net/action_products/965623/955528
Marcel
Mhwlng
DMX moodlight panel
Post by Mhwlng »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">If you have the Lanbox, the following device - Solarox DMX RGB stripe controller - is quite interesting as well,
I just found this similar? device (dutch language only)
http://www.thewillows.nl/web2shop/?page ... tegory_id=
there is a lot of dmx stuff on this site including a wireless dmx controller based on zigbee technology [8D] ....
Marcel
