First use of X10
Malcolm T
First use of X10
Post by Malcolm T »
Hi All.
Before my first use of X10.
System could be two time clocks with four circuits into a TMA4 at the remote end and four AD10 in a control panel.
Q1 Do I need to program these devices? As I understand it the TMA4 is supplied coded A1 - A4 and I can set A1 - A4 on the AD10s.
Q2 There will be an MCB between the two devices, will the signal be inhibited by the coil in the MCB?
Q3 Should I change to Xanura for the higher signal levels?
Thanks in advance, Malcolm T (Dartmouth UK)
Peterpc
First use of X10
Post by Peterpc »
<i>Q1 Do I need to program these devices? As I understand it the TMA4 is supplied coded A1 - A4 and I can set A1 - A4 on the AD10s.</i>if you use a1 to a4 you don't have to program them
<i>Q2 There will be an MCB between the two devices, will the signal be inhibited by the coil in the MCB?</i>
it is possible your signal will be weaker.
<i>Q3 Should I change to Xanura for the higher signal levels?</i>
TMA4 has same signal level as the Xanura module.
