Albatron - Network share
Forum about all kind of Touchpanels & Displays.
Erik
Post by Erik »
What tools are used to setup a network share on W-CE6.0.
I want to avoid swapping SD cards.
Erik
Post by Erik »
I decided to use the freeware W-CE client of Total Commander.
It will offer you in one screen the directory structure of the Albatron and your Desktop PC. It allows to manipulate files across the network. Albatron and Desktop need to be in the same network domain.
You can find the freeware at http://www.ghisler.com/wince2x.htm To install, download the tcmdwincearm.cab (link: CAB , arm/xscale/pxa) unzip the file 000CECMD.002 and rename it to CECMD.EXE, copy this file to the Albatron. I did not try the beta version 2.52 which should support FTP via SSL.
DJF3
Post by DJF3 »
Where did you configure the domain on the Albatron?
WinCE total commander looks great!
Erik
Post by Erik »
The domain is in Control-Panel/Owner -> Properties -> Network-ID
I noticed however that it is not taken into account using the W-CE Total Commander.
DJF3
Post by DJF3 »
All,
To access network shares I had to connect first:
-Open command prompt and type: net use * \\<serverhostname>\<sharename>
-Enter username & password when requested. Now you can access these shares.
(also from the Total Commander)
DJ
Bastiaan
Post by Bastiaan »
I used the built in Windows Explorer...
Just type \\share and I could access all folders and servers....
Did I miss something?
Return to “Touchpanels, Displays & UMPC devices.”
