I discovered that after the update's the module nr are changed!!!!!
one example circle 8c05c is now 38c05c??????? Tu's the sticker one the device is not correct any more. Also the circle+ is change.
They added a digit extra on the modules
Gr Ruud
Module name are changed
- Member
I've seen it as well, but you do see the system I hope?
With me a 3 is added in front as well.
It's working but not as nice as with the source one.
Network recognition sucks
gr Ruud
gr Ruud
- Member
Err, what are you using besides source then?
with me there is a "2" added. v 20090620.0
@Jos
it started with The Source 1 and now there is The Source 2
And i use Homeseer plugin (plugwise)
Gr Ruud
Gr Ruud
