My CTX35 not working?
Maarten
Post by Maarten »
I have a CTX35. when i send A5 on it is not working. any body now a problem ther are 2 led's blinking on the CTX35 and when i do the test progam it is working fine but no lamp going on.
(sorry voor slechte engels ben er niet goed is haha)
Did you try other modules as well?
You could be having trouble with noise on the powerline!
Check this forum there is alot of info about this.
And try moving the module to another outlet for testing...
Maarten
Post by Maarten »
i have found the problem the can not in a (stekerdoos).
Any body have the same problem?
drmacchi
Post by drmacchi »
Marten, I have ctx35, but i didn't understand what is your problem!
DJF3
Post by DJF3 »
Maarten,
-How did you test the CTX35?
-Have you unplugged/plugged-in your CTX35?
-"A5 is not working": how exactly did you test?
-Are other devices working fine? (if yes, what is the difference?)
-Can you test with a lamp that is in the same power socket?
-Do you have RFXCOM?
-Where do you send A5 from? (HomeSeer, Remote, X10 switch)
Also checkout this thread: http://board.homeseer.com/showthread.ph ... ight=ctx35
DJ
Maarten
Post by Maarten »
When i put it in the meterkast only the lamps stread in the stopcontact works.
When i put it in the stopcontact made frome the bulder everything is working how is this posible?
Sorry for my bad engles i can only read engels not write.
drmacchi
Post by drmacchi »
-try another lamp module
-try different address module
- when you use ctx35 test utility, you see leds blinking but you have data scrolling in utility too (using auto option). do you see data flow in the sw window?
As I told before you probably have interference on your powerline. Certain devices which are in the proximity can heavily interfere with the signal causing instability. Did you apply any filters?
Maarten
Post by Maarten »
i dont have a filter. i buy some filter en test then again.
Thanks for the help!
